Announcements
Derived components don't update with their parent
s.daniele01
s.daniele01
Good morning everyone,
I have a new bug to propose to you, let's take into consideration a design assembly "X", in this design I derived design A, and linked (inserted) designs B and C.
Design A is empty and only has a bunch of parameters that I need in my designs, design B is also derived from design A as it uses the same parameter list as X, and design C is derived from B but slightly edited.
If I now edit some parameters in A and save, open X and bring all components up to date, X, B and all components directly derived from A will update successfully and become a new version of each when I save, but component C will not get updated immediately, and one of two things will happen, either after B gets saved by X, it will realize C is out of date and let me update it, or it will think it is completely up to date, and I will have to open B, save a new version without changing anything, open C, bring it up to date with B, and then update X again.
I'm sure you could see how this would become very frustrating very quickly.
Looking forward to any help,
Have a great day,
Daniele.
dsouzasujay
Hi @s.daniele01
Sorry to see that you're facing a problem.
I have created similar data, based on my understanding from your description, I believe this is the structure (If not please correct me)
X (Main Assembly)
  • A(Derived)
  • B(External Reference)
    • A(Derived)
  • C(External Reference)
    • B(Derived)
Open A, modify 'A' Parameters and Save the design.
When you open 'X', 'B' will be Out-of-Date, Get Latest update, Save. (This will Create new version of X)
Right after saving 'X', 'C' will be Out-of-Date, Get Latest update, Save.(This will Create new version of X)
(No need of opening documents in a a separate Tab/New Tab)
I don't see a problem here, can you please correct me if my understanding is wrong.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
s.daniele01
Hey @dsouzasujay, thanks for your attention.
Yes the structure seems to be correct to me, I'm not sure if it's important but C is not a component that contains both a component and a derived B component, it is only the derived B with more holes added to it.
The steps you took seem to be the same as mine, but
Right after saving 'X', 'C' will be Out-of-Date, Get Latest update, Save. (This will Create new version of X)
Does not seem to work consistently, sometimes it does immediately appear out of date, other times it will just say it's already up to date, and I will have to create a new version for B because even opening C it doesn't say that the derive is out of date (not sure if there's a way to make it check again without creating a new version, I only tried CTRL+B).
Even if it did work consistently, I think it would be more convenient if there was an option to have it update both B and C at the same time, but I'm not sure that could be done without creating a new version for B (which would be acceptable if it was a togglable option or something).
Thank you very much for your time.
Daniele
dsouzasujay
Hi @s.daniele01,
Does not seem to work consistently, sometimes it does immediately appear out of date, other times it will just say it's already up to date, and I will have to create a new version for B because even opening C it doesn't say that the derive is out of date (not sure if there's a way to make it check again without creating a new version, I only tried CTRL+B).Even if it did work consistently, I think it would be more convenient if there was an option to have it update both B and C at the same time, but I'm not sure that could be done without creating a new version for B (which would be acceptable if it was a togglable option or something).
If there is an inconsistence with the file, it will be a bug.
Would you be able to invite me (Sujay<dot>dsouza<at>autodesk<dot>com) to that project?
That'll help us investigate the issue.
There is no way we can Update B & C at the same time.
I can explain with example
So below is the initial design, with all versions of V1
Now, Modify ‘A’ Document and Save. All 'A' documents will be now with V2
Now, in assembly 'X' document, Since 'A' has new version, 'B' will be out-of-date.
Get Latest updates for Document ‘B’, Save.
When we save, it will be of below state
Since, we have a new of version of ‘B’, 'C' will be Out of date, So we need to Get Latest updates for Document ‘C’.
No way we can Update B & C at the same time.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
