Announcements
Derive bug
wmhazzard
Derive bug
wmhazzard
I derive a component into a new design, tick the box Place objects at origin and the objects are not placed at the origin in the new design. Am I doing something wrong or is it a bug?
HughesTooling
Just testing and it seems like it only moves component origins to the origin also it doesn't seem to affect sub component.
In this example if I export the Side Core Assembly nothing moves because it's origin is already at the at origin. But if I Derive just one of the side cores its origin is moved to the origin.
Mark Hughes
Owner, Hughes Tooling
dsouzasujay
Hi @wmhazzard,
Not a bug, Its as-designed
So, what happens when we check\uncheck "Place Objects at Origin" while deriving a component? what is the difference?
  • When upstream moves the target occurrence, it will do/don't change the position of the derived geometry.
  • The "Place at origin" option is meant to align a Component Origin with the Global Origin in the Target
I can give a simple example
  • Lets create a document with a local "Component1" with a small cube, Save it as 'A'
  • Derive "Component1" to a new document
  • While derive, we will have 2 options
    1. Case 1 : Check "Place at origin" option
    2. Case 2 : Uncheck "Place at origin" option
  1. Case 1 :Check "Place at origin" option, Save the document as "B_Case1"
    • Move the component1 in 'A', capture position, Save
    • Switch to 'B' document, Get latest Updates
    • Nothing happens
  2. Case 2 : Uncheck "Place at origin" option, Save the document as "B_Case2"
    • Derived "component1" will move.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
wmhazzard
Thanks for the clarification.
