Deleting offset plane also deletes section view?
FrodoLoggins
Advisor Advisor
FrodoLoggins
When creating the section view I selected the offset plane as the cut plane. Is this new behavior?
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
seth.madore
I don't think it's new behavior, but thinking about it some, this makes sense to me. I mean, if a section analysis is based off a plane that no longer exists, where should the analysis be looking?
Seth Madore
FrodoLoggins
Because I need the section view not the offset plane 😛
Totally makes sense to change the behaviour but if this wasn't a change it would be nice if it got fixed.
seth.madore
I can't say one way or another if this behavior existed before, so unless there's some certain evidence of that behavior (or numerous reports of such) it's likely to remain as-is
Seth Madore
davebYYPCU
You do need the Construction Plane, to keep a Section View tied to it.
You can Offset the Section View to the same location, without a tied Plane,
Other than not making the Construction Plane in the first place, Nothing to fix.
Might help....
