Delete unwanted edge lines when exporting pdf file
I have created a drawing using the pipe tool (Design.png).  However, when I exported the drawing to the pdf file using Drawing --> From animation, it shows ugly lines at the corners (Exported PDF.pdf).  I was able to remove those lines(or make them invisible) in the Design mode by setting the Visual Style as Shaded.  However, when exporting the file, those lines showed up again... I've already set the Tangent Edges to off, and unselected Thread Edges in the Edge Visibility in the Drawing panel.  Also, I unselected Lineweights in the Output PDF panel as well.  But all those settings didn't help.  Any suggestions are appreciated!
rmkolaks
Do you see the same issue when exporting to a jpg?  If not then export to jpg and include the jpg in your pdf.
Exporting to jpg works! The quality of the figure looks great too.  Thanks a lot!
