I you can drag the feature for the extrusion of the hole past (to the right) of the feature that created the drop-down boss it will cut the section of the boss away. It is history moving from past (operations toward the left) to the present (operations closer to the right) so if the extrusion happens "after" the drop-down boss, it will cut it. On questions like this, if you attach your model, the forum users can create a Screencast to show you the process. To attach you model, open the model, go to the File menu and chose Export to a folder on your local drive. Then attach it to your post using the Attachment section below.
John Hackney, Retired
