Delete key and right click delete not working on lines created whilst in sketch mode on iMac
adamjedgarDSMJ3
adamjedgarDSMJ3
Hi guys,
I have created some lines in sketch mode on an iMac.
If i then attempt to delete these lines whilst in sketch mode using either delete key or right click delete...it is refusing to delete anything at all.
The only way i can delete is to finish sketch and then delete sketched lines whilst in 3d.
Has anyone else had this problem with this program? Why is it not allowing the delete command to work in sketch mode when i am trying to delete lines i created in that mode?
I am doing this from a brand new drawing...i simply choose sketch, draw a straight line, and then attempt to delete it...nothing happens. When i finish sketch, the line is clearly visible in 3d.
Is this a bug or am i doing something wrong?
mohammed.aliTDPXK
Hello @adamjedgarDSMJ3 ,
1. Can you please see if you can delete it with the delete button on keyboard?
2.  Do you have multiple sketches and if you are deleting the lines of other sketch?
3. Can you please share the model here such that we can have a look?
4. Also  please send me the diagnostic log files when this happens.
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
