Announcements
Default setup sheet post moved?
ltomuta
ltomuta
After today's update my setup sheet customizations are gone. Business as usual, so I went on to try to replace the installed copy with my customized one. But...
- There is only one setup-sheet.cps in the entire %userprofile%\AppData\Local\Autodesk\webdeploy\production directory.
- The file seems to be where it belongs, under \644cb3fb363c9e2881e69c03ab808028604773bd\Applications\CAM360\Data\Posts where 644cb3fb363c9e2881e69c03ab808028604773bd is today's update's directory.
- the file is my version of the file, with customizations (copied from the old instance as part of the install?)
- this file is NOT the one used to generate the setup sheet as none of the customizations are showing.
Did you guys make any setup sheet related changes?
ltomuta
New file location: %userprofile%\AppData\Roaming\Autodesk\CAM360\cache\posts\setup-sheet.cps.
Is this a new thing or a new bug?
ltomuta
Ok, so the file really is cached now and every time I start Fusion the file is fetched from somewhere (where?) and it replaces my cusomized one. Not cool!
