Fusion Support
Decals not showing up in renderings all the sudden.
6 REPLIES 6
variant1
1482 Views, 6 Replies
Local renders. No, it's not a normals thing, we use templates to render third party branding onto products. Did I accidentally toggle something off? No file renders right now.
I don't see an option in the render menu to turn them off.
I swear its a new issue every other day with this software. 😕
Tags (1)
6 REPLIES 6
jodom4
in reply to: variant1
Hey variant1,
Can you share an archive so we can take a look?
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
variant1
in reply to: jodom4
Now its working all the sudden, except all the renders I queued after toggling a different label on (typically, there are multiple SKUs), have all rendered as the first label.
Any plans in actually finishing the software?
variant1
in reply to: jodom4
Basically, I've got to shut the software down entirely every time I change or add a label and reopen it or I get a render with no label on it. Man Mad
The company is going to switch to Keyshot here soon and I cannot wait. I'm so tired of playing Russian Roulette with which feature won't work right on any given day.
lucasproko
Hey @variant1,
I'm sorry to hear you're having issues with our rendering workspace. I understand there's a big frustration when things don't work how you expect them to, and I can assure you, our focus moving forward is on reliability.
That being said, I'm curious for a bit more information on the problem you're describing. In my tests, changing decals, and then creating new renderings results in the behavior I would expect. Namely, each new rendering correctly displays the decals that are present when the rendering is queued. Could you elaborate a bit more on your exact workflow so I can try and replicate it?
Also, are you using Cloud renderings, or Local renderings?
Lucas Prokopiak
Fusion 360 Product Manager (Sketch/Model)
britdizzy
in reply to: lucasproko
I've been having the same issue with decals being there and rendering fine, then they disappear. the decal is still present, and when you select it, it shows as a blue square, but will not show when in the design or render space. I have replaced decals, and the same thing happens over again.
@lucasproko
hope you can help.
hotlipsporter
in reply to: britdizzy
I'm having the same exact problem. Decals have been showing in renders no prob and then all of a sudden, nothing! Come on Autodesk, you guys gotta come up with a solution for this...enough people are having the same issue. There isa bug!
