Decal moving when making hole, and not able to precise aply decal to face/body
Hello, im having some problem to create holes in my body after i have applied a decal. Im trying to render a PCB i have made and first i made a body for the right size, then applied a decal. But when i try to right click on it and make holes for the soldering points the decal is moving then i try to make the hole in the middle.
I placed the circle in the middle but when i click OK to make the hole every thing is shifting.
But only the middle part, i can do every other soldering point like this without shifting:
As you can see here.
And another problem i have is that i cant apply a decal and resize it to the exact right size using the Texture Editor tool:
Im not able to set the exact size (17.91mm × 15.37mm) at the Scale option it is chancing for me to the closest mm, i think. Only way is to Insert a Decal and then eye ball it to place, and i don't like that in a CAD tool.
Hope you can see my problems and that there is a simple solution for this 😄
Thank you for reading,
/Eric
