This has been happening for some good number of Fusion versions. Steps to reproduce bug:
-Create a cube
-Assign a decal to a face with filename decal1.png for example
-Change decal1.png in some image editing software and save it in same place as where you initially had it
-update the decal image
-....see no change in the decal
If you change the name of the decal file, then it works. If you keep the name of the decal the same but have it in a different location on your local drive, then it works.
It is as if Fusion is saying, "Oh, since you are trying to change the decal file with the exact same path and filename, that underlying file just MUST be identical to what I have, therefore I am not going to re-read it, I know best!"
Thanks!
Nick Kloski
