Novice user here. I did search the forums for this but I didn't find anything quite like it so here it is.
I'm trying to deboss an SVG on a cone-shaped lid from above, meaning the SVG is on an offset plane directly above the peak.
I've tried a simple deboss on a solid body, which fails.
I've tried to deboss a flattened sheet metal cone however the pattern disappears once its unflattened.
I've also tried using a boolean against the flat pattern, which works until it's unflattened.
Last issue and it may be a limitation of F360, it seems like the cone will not flatten if it comes to a peak (have a workaround but still...)
Are there other methods or am I trying to do something F360 just can't do?
Also watched @jhackney1972's sheet metal cone vids. Thank you for that btw!
Any help would be most appreciated!
