Announcements
Data panel - Missing Thumbnails?
jon46XEC
jon46XEC
Not a giant problem, but I do find the thumbnails are helpful.
Not sure why a couple have disappeared. Any way to get them back?
Thanks! -
Replies (8)
P-BvanWyk
Good day @jon46XEC,
I found that it sometimes helps to clear the cache.
Alternatively, try opening the files to ensure that they are uploaded correctly.
Please click on Accept Solution to help other community members solve their issues.
Also, consider giving a Like to the comments that you feel added value.
Kind regards,
Pieter-Ben van Wyk
jon46XEC
Thanks for the tip, however this did not work. Still a blank thumbnail
P-BvanWyk
Good day @jon46XEC,
Please have a look at this similar article.
Hope it helps.
Kind regards,
Pieter-Ben van Wyk
jon46XEC
Thanks very much. Well, it seems to be a growing problem with no fix yet:
roberto.armellin
Hi, same problem for me.
The preview image is not shown either within Fusion360 or on the fusion website.
I have tried all the proposed solutions but nothing, the preview image does not appear.
There are no objects far from the center.
I have also tried exporting the model, deleting it, and re-importing it, but the problem persists.
See screenshot.
jon46XEC
Until there is a fix, the only way I have been able to get the thumbnails back
is to start a new design, then select the file in the data panel and "insert into the current design".
Then break link drag everything out up to the top level and save.
Note: If you have manufacturing setups, copy those from the original file and paste into the new manufacturing tab.
You will have to reselect and reattach all the part geometry for the machining steps.
P-BvanWyk
Thanks for sharing the workaround @jon46XEC.
Lets hope the next update fixes it.
Kind regards,
Pieter-Ben van Wyk
roberto.armellin
Great !
Thank you @jon46XEC ,
your workaround works !
