Fusion Support
cutting two bodies
15 REPLIES 15
Message 1 of 16
baloshUSCM9
370 Views, 15 Replies
cutting two bodies
Hi. I am trying to build a bowl by cutting two bodies, each with a different color. But the result is a bowl with one color. I intend to get a two-color bowl. What am I doing wrong?
15 REPLIES 15
Message 2 of 16
g-andresen
in reply to: baloshUSCM9
Please share the file for reply.
File > export > save as f3d on local drive  > attach to post
günther
Message 3 of 16
baloshUSCM9
in reply to: g-andresen
Thank you.
If I cut, the 2 colors stay, but with swivel command, only one color stay.
Message 4 of 16
@baloshUSCM9
Message 5 of 16
Thank you
If I cut the colors stay.
In a swivel command, the colors disappear.
Message 6 of 16
g-andresen
If you share the file there would be a chance to analyze the situation and give hints to possible solutions.
günther
Message 7 of 16
@baloshUSCM9
No file Attached?
Split Face.
Appearances (by Face).
Message 8 of 16
baloshUSCM9
Here is the file
Message 9 of 16
g-andresen
create 1 revolve body, split the faces and give them different appearances
günther
Message 10 of 16
baloshUSCM9
Thank you. I understand.
But it doesn't resolve my problem.
My goal is to CNC wood in shapes to get a nice colors appearance from 2 or
more wood layers from different colors.
I want to CNC shapes on the wood layers and the glue them and then CNC
again.
Shapes like that for example
If I cut, it is working well, but swivel is "deleting" the colors.
Can I maintain the colors with swivel command?
Thank you very much for your time
With best regards
Yeshayaou Balosh
Message 11 of 16
g-andresen
Missing!
Might help
Message 12 of 16
baloshUSCM9
Thank you.
It is good to know that it is possible.
But for an unknown reason for me, I see only one color, with my Fusion with your file.
I can't figure it out, why it is so? please look here down.
Thank you very much
Message 13 of 16
timeset2500
Try this:
This is a tool used to quickly make objects more visible when working on a document; I imagine it was likely turned on because the wood textures were difficult to see sketch objects and surface bodies through.
Message 14 of 16
baloshUSCM9
Thank you for your help.
Your file is working fine.
Mine isn't.
When I am trying to divide it, I got an error massage.
First, why do I got the upper ted body?
And here is the error massage
Can you please cutting my two bodies, in my file so I can undertand w=hat am
I doing wrong?
Thank you very much
With best regards
Yeshayaou Balosh
Message 15 of 16
Mine isn't.
Can you please cutting my two bodies, in my file so I can understand what am
I doing wrong?
@baloshUSCM9
Did you mark this issue as solved?
Is it really solved?
First thing I notice is that there are no dimensions in your Sketch1?
Message 16 of 16
Hi
That was only a test case in order to see what can be done.
Now, thanks to your help, I know what to do.
I will draw more complex shapes in order to find a nice CNC body.
With best regards
Yeshayaou Balosh
