Announcements
cut a sketched hole into a mesh converted into a solid
wcleary
Observer Observer
wcleary
Observer
Observer
I have tried everything except for the answer I'm looking for hoI am trying to cut a sketched hole into a mesh converted into a solid but I always get an error saying there is no solid to cut. Help
jhackney1972
Probably it converted into a Surface body instead of a Solid body.  Attach your model and let the Forum users take a look.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
TheCADWhisperer
@wcleary wrote:
I have tried everything…
Help
@wcleary
Where did you go?
Does your browser show the glyph for a Solid Body or does it show the glyph for a Surface Body?
