Custom Thread won't model
u.spaeth
Message 1 of 8
u.spaeth
Community Visitor
Community Visitor
//Edit:
Guess I found the problem... PitchDia != Pitch. Gotta calculate that separatly. Haven't found out yet how...
this is my first try on designing a custom thread. I copied, renamed and edited the DIN-Pipes file and my custom thread shows up fine in Fusion 360 and can be used - but not modelled. It gives an error.
I wan't to create a VG8 (both, bolt and nut) as can be found here:
https://www.gewinde-normen.de/en/valve-thread.html
This is my implementation:
<ThreadType>
  <Name>DIN Ventilgewinde</Name>
  <CustomName>DIN Ventilgewinde</CustomName>
  <Unit>mm</Unit>
  <Angle>60</Angle>
  <SortOrder>18</SortOrder>
  <ThreadSize>
    <Size>8</Size>
    <Designation>
      <ThreadDesignation>VG8</ThreadDesignation>
      <CTD>G 1/16 </CTD>
      <TPI>32</TPI>
      <Thread>
        <Gender>external</Gender>
        <Class>A</Class>
        <MajorDia>7.747</MajorDia>
        <PitchDia>0.794</PitchDia>
        <MinorDia>6.631</MinorDia>
      </Thread>
      <Thread>
        <Gender>internal</Gender>
        <Class>A</Class>
        <MajorDia>8.061</MajorDia>
        <MinorDia>6.945</MinorDia>
        <TapDrill>0</TapDrill>
      </Thread>
      <Thread>
        <Class>B</Class>
        <MajorDia>7.616</MajorDia>
        <PitchDia>7.035</PitchDia>
        <MinorDia>6.561</MinorDia>
      </Thread>
    </Designation>
  </ThreadSize>
  <ThreadSize>
Of course I found https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Cus... and double checked my values.. what did I miss? (Class A, ignore B (unchanged))
Replies (7)
Message 2 of 8
Ketherton21
pitch diameter is the difference between your threads major and minor diameters total.
Message 3 of 8
TheCADWhisperer
What standard are you using?
Do you have a reference (something like this)?
Edit: I see now DIN - Pipe.  I withdraw my comments as I have no experience with that standard.
Message 4 of 8
I'm trying to model the same thread. So in this case the PitchDia would be 7.747 - 6.631 (Major - minor)?
@u.spaeth Have you successfully modelled that VG8 thread?
Message 5 of 8
HughesTooling
In the post above the pitch diameters for the Class A threads are definitely wrong. Does the external class B thread work? The page from link in the first post doesn't show pitch diameters and also doesn't show how to calculate it in the diagram so you'll need to find better info.
Mark Hughes
Owner, Hughes Tooling
Message 6 of 8
I think the right calculation seems to be: PitchDia = (Major - Minor) / 2 + Minor
So this should be the correct file for a VG8 thread, as it works in Fusion, but I haven't tested it in real life
<?xml version="1.0" encoding="UTF-8"?>
<ThreadType>
  <Unit>mm</Unit>
  <Angle>60</Angle>
  <ThreadSize>
    <Size>8</Size>
    <Designation>
      <CTD>VG8</CTD>
      <TPI>32</TPI>
      <Thread>
        <Class>A</Class>
        <MajorDia>7.6835</MajorDia>
        <PitchDia>7.1255</PitchDia>
        <MinorDia>6.5675</MinorDia>
      </Thread>
      <Thread>
        <Class>A</Class>
        <MajorDia>7.9975</MajorDia>
        <PitchDia>7.4395</PitchDia>
        <MinorDia>6.8815</MinorDia>
      </Thread>
    </Designation>
  </ThreadSize>
</ThreadType>
Message 7 of 8
HughesTooling
No it doesn't work like that. Internal threads have a more pointed peak and more truncation in the hole so the pitch diameter is closer to the minor diameter and external threads are the other way around.
You have about 0.3mm difference in pitch diameter for external\internal. That's way too much, if you look at a similar size like M8x0.8 it's about half that.
Something like this for standard metric threads.
Mark Hughes
Message 8 of 8
I looked at some British Standard Pipe Parallel Thread tables and that was exactly how the pitch diameter was calculated. I'm not a thread expert, so I don't what to do otherwise.
whitworth-pipe-thread-ei
