Custom text not cutting correctly
FINK v1.pngThe "A" and the "R" in TEACHER is not cutting correctly. I have attached My files to this post just in case its a file issue.
jhackney1972
Somewhere along your design path, you removed some key bodies and sketches.  I had to create bodies at the error locations to fixed the issue.  If I missed the thickness of the outlines, just change the offset distances of of the extrusion - cut sketches.  Model is attached.
John Hackney, Retired
