Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Curves display issues
2 REPLIES 2
pierre-antoine_berthy
190 Views, 2 Replies
Hello Everyone,
Since I updated to the latest Fusion 360 version, I'm having an issue with the solid curves.
As you can see attached, the previous model I've rendered, the curves are smooth, but since the update the curves are no more smooth (The model and construction is the same).
How can I fix it?
Thank you very much for your quick help that is much needed
2 REPLIES 2
Please share the problematic model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
Hi John,
Thank you very much for your reply.
I can't really share this 3D as it is quite confidential.
But I have more inputs to give you:
-It seems to be settings issues that have changed since the new update.
-All my previous 3D before the update are smooth, but the new ones I created after are not.
-When I export my new 3D in STEP for rendering the curves are smooth, but they are not on fusion
Is there any settings that reduce the quality of the previsualisation of the model in Fusion?
Thank you for your help
