Cursor bug in newest version
crueby1
Message 1 of 10
crueby1
In the new version, you added the ability to resize dialogs from any edge. Looks like the cursor handling is messed up though - it changes from the arrow to the little resize arrow on dialog edges like it should, but it is doing the same thing in many more places too!  When moving the cursor over body/component names in the browser, over text boxes inside dialogs, places like that, it is ALSO changing the cursor when first moved to those places. If it is moved away and back, it goes back to the arrow again. Very disconcerting.
I am on latest Windows 10, display drivers are latest available.
Screencast showing this is attached.  um... captured but it failed to upload - working on that...
Replies (9)
Message 2 of 10
crueby1
Okay, just saw that Screencast has been discontinued, had not noticed that. So, here is a new video showing the bug... after a lot of messing around to find out how to capture one! Why the heck do you retire a tool without replacing it??  STUPID!
Anyway, video of bug attached...
Message 3 of 10
crueby1
This bug is there all the time, multiple restarts/reboots have not helped
Message 4 of 10
jhackney1972
I do not see any of this in my Fusion 360 application.  I too am running Windows 10.  I would suggest you get out of Fusion 360 and run the Repair Option in the Fusion 360 Service Utilities.
John Hackney, Retired
Message 5 of 10
crueby1
Tha appears to have fixed it!
Thanks!
Message 6 of 10
RSHEETSTBRDK
I am having a similar bug, the service utility will NOT launch.
Message 7 of 10
crueby1
Even though the service utility seemed to fix this bug (which a number of other people are seeing too) at first, it really didn't help, the cursor bug is still there. I opened another thread on it since this one had been marked (too soon) as fixed. The bug has been there in the last couple of releases.
Message 8 of 10
RSHEETSTBRDK
I fixed my issue with graphics card driver update
Message 9 of 10
crueby1
Latest driver didn't help my case, unfortunately.
Message 10 of 10
viaD6QPP
It's been over a year since this post and the problem has not been fixed.
The problem with the cursor appears after opening the "Physical Material" window and also when opening the "Appearance (a)" window, after that there is a bug with the cursor when pointing it at the model tree. Only rebooting Fusion helps.
This is just unbearably annoying ... can the development team fix this ?
Thanks in advance for your reply.
