CTL + C not working
jldriggers75
CTL + C not working
jldriggers75
This just started happening. When I try to copy and paste text in a Fusion 360 drawing I get a message "Item not collected: Format not supported by Office Clipboard. Any suggestion to fix this?
jhackney1972
It works just fine on my end.  Create a video of your own to show the process and problem you are using.
John Hackney, Retired
jldriggers75
I get a message that Autodesk has discontinued Screencast
jhackney1972
That is correct, you can use any video capture application you desire to create an MP4 video and attach it using the video icon above in the toolbar.  Here is a free one if you would like to take a look.
jldriggers75
The error I was getting in the bottom right corner of my screen didn't show up on the screen capture. "Item Not Collected: Format Not Supported. I restarted my computer and I still get the message but if instead of right clicking the text, if I just select the text and use ctl+c, ctl+v on my keyboard it works just fine. If i right click and select "copy" on the screen menu it doesn't work but I get the error message with either method.
jhackney1972
All I see in the video is the highlighting of some label text.  I do not see any right click "copy" dialog box at all.  I am afraid I cannot verify this problem or help solve it.
nemadec
@jldriggers75
We are unable to capture the issue in video but can provide following details :-
  1. Which font you are using the text you have selected for copy?
  2. Have you used that font in your previous drawings?
Chandrashekhar Nemade
Sr. SQA Engineer
