Fusion Support
Crosshairs Effect in Drawing Workspace
4 REPLIES 4
emkimZRXN
182 Views, 4 Replies
When working in the drawing workspace, my entire screen freezes, I can't click anything, and my cursor becomes something that looks like a crosshair. It's been consistent--I don't know whether it has to do with updating the software or just a general bug... please help asap.
4 REPLIES 4
jhackney1972
in reply to: emkimZRXN
Can you capture a screen to show what you are seeing?  Also, does it happen on all models or just one, if one please attach.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
emkimZRXN
in reply to: jhackney1972
jhackney1972
You did not answer the questions?  Anyway, if this is for all models, when you create a drawing, I suggest you use the Fusion 360 Service Utility to Repair your application.
John Hackney
Retired
emkimZRXN
Sorry, I was confused by what you meant by 'models'
If you mean that this issue occurs with every design I try to convert to a drawing, then yes, this issue persists. I will look into Fusion 360 Service Utility, thank you.
