Fusion Support
Creating new Bodies from faces issue
1 REPLY 1
Elitepiercings
53 Views, 1 Reply
Haveing an issue where creating a new bodies from a face is cutting part of the face from the new body not sure whats causing it but I did the process exactly the same as I did the layer below with the green post and it didnt have this effect also when doing a circle pattern on the top row the cut dissappears as I wanted from the start but it says on the starting post. New to fusion hope this makes sense
1 REPLY 1
Please attach your model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
