Creating Cyclinder
Creating Cyclinder
Creating Cyclinder
Hi there! I'm struggling on finding out how I can possibly make a cylinder? Hopefully like the one included 🙂
jeff_strater
That is a T-Spline (or Form or Sculpt) cylinder.  You need to create a Form feature, which then puts you into the Form environment.  There is a Cylinder command in that environment.  Screencast coming soon, as soon as it finishes processing
Jeff Strater
Engineering Director
jeff_strater
screencast below.  Just out of curiosity, why do you want to create this type of cylinder, as opposed to a solid or surface cylinder?  I assume that is just a starting point for a design to be done in the Form environment.  If you need a precise cylinder, use the Cylinder command in the Solid or Surface tool set.
Jeff Strater
Hi. Yes, I'm just trying to follow some instructions on how to make a lolita hat for a joker figure I've recently made.
Thanks for the previous help. I'll try it all out now 🙂
