Announcements
Creating a slope on sink
infoJH98V
infoJH98V
I am designing a vessel sink and I need to figure out how to make the base of it sloped to a drain. We are making both a circular and a oval shape.
Replies (8)
g-andresen
Please share the file.
File > export > save as f3d locally  > attach it to the next post.
günther
infoJH98V
Here is a quick model of the oval sink. I need to slope the bottom plane so that the water flows to the drain. This is being cut out on a CNC machine out of wood or foam. Then we cast it with rubber and then cast it with concrete! Thanks for you help!
TheCADWhisperer
Your Fillet sizes do not make sense?
For uniform wall thickness the Inside Radius should be Outside Radius-Thickness.
infoJH98V
Thank you that helps as well. To get the bottom of the sink to slope toward the drain hole do you have any suggetions? Ive added the round sink as well
TheCADWhisperer
See Attached...
g-andresen
try this:
Screencast
günther
TheCADWhisperer
Where are your sketches?
TrippyLighting
Why are there no sketches in this design?
