creating a cat ear ring (jewellery)
navpat
navpat
hi all,
i'm trying to create a cat ears ring (like in the pic attached) but i cant seem to attach the ears to the ring exactly. i've attached the f3d file. please help if you can 🙂
thanks in advance!
ryan.bales
Autodesk Support
Autodesk Support
There are likely half a dozen ways of doing this. I went back, used emboss, then boundary fill to create a the outside bodies. This involved shrinking down the original extrusion diameter by 2mm then making it as tall as the ears. from there boundary fill to create required bodies for the ring profile and combine. I'm also sure there are simpler methods but this was a quick stab at it.
Ryan Bales
Fusion 360 Product Support
navpat
thank you! this really helped!
