Create Master Sheet Metal Design with Bend Variants
Hey Folks! I'm trying to follow the steps provided in this post on How to Create Component Variants with my sheet metal design and I'm not able to convert it to a component (first screenshot). The reason I want to do this is so that I can edit the master design and have changes flow down to the variants which will have bends in different directions (essentially mirrored - second/third screenshot) or other features added to the design variants.
Right now, it seems I have to copy the design into different files and break the link between the master and the child variant which then leaves me having to make changes that should be in the master in each separate variant.
I also tried to follow the steps above and make the master a flat piece, and then insert into a new design to bend it, but I can't select the "stationary face" to start the bending process (screenshot 4).
The other option I can think of is just to have a master sketch, and insert that into new designs/files and start with the create flange step and proceed from there. BUT.... I'd like to bake as many common steps into the master before creating the variants to save work in the variants.
Hopefully I'm missing something obvious, and thank you!
