Create Box Bug
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In the last couple releases I have seen cases when I try and create a box on an existing face, and it wont work, the dialog box and display are all messed up. Finally hit a model where it repeats consistantly. Here is what it should do, when I do a Box create command, and picked the end of the cylinder to place it on - clicked on the face, then the start/end points of the rectangle, and it comes up looking like this, which is all normal:
Create box on face, worked normally
But, if I try and create a box on the larger face behind it, it does not work properly. Clicked on the face, then drew the start/end points of the rectangle, but after setting the end point it instead looks like this:
Create box, failed to work
Note that the display of the box is incomplete, and the dialog box that pops up is missing most of its entries. Clicking again on the face where the box is supposed to be then makes it even worse, like this:
After clicking on face again
This behavior is very odd, just started in the last couple of weeks. I have gone through settings for the graphics, changing things one by one, no change. I am on windows 10, latest drivers all round, 32 gig memory.
