Fusion Support
Crashes after reporting being offline for more than 2 weeks
2 REPLIES 2
rhouse21
60 Views, 2 Replies
Fusion is crashing on both of my computers after reporting that it's been offline for more than two weeks. I click "yes" to allow it to connect to the internet, then it reports it's not online and closes.
2 REPLIES 2
@rhouse21 Can you please do the following?
1. Close Fusion
2. Go to add remove programs
3. Select Fusion - Select Modify
This will launch the Fusion serve utility
4. Run the reset fusion from here
Now start Fusion and see if that solves the issue.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Thank you for your reply. It turns out the problem wasn't either of my computers. For some reason my router was blocking traffic but it fixed itself after a reset.
Thanks again!
