Announcements
Crash while open electronic library
spike.moa
spike.moa
This happens after the recent update.
Please help.
[GPU Information]
GPU Device: Intel(R) HD Graphics 630
GPU RAM: 128 MB (Integrated card)
GPU Driver API: DirectX 9.0
GPU Driver Version: 27.20.100.9466
GPU Driver Date: Unknown
[Graphics Effects Settings]
Anti Aliasing: Off
Ambient Occlusion: Off
Object Shadow: Off
Ground Shadow: Off
Ground Reflection: Off
Selection Display Style: Simple
Transparency Effect: Better Performance
[Limit effects to optimize performance]
On
jodom4
@jorge_garcia , can you take a look at this?
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
jorge_garcia
Hi @spike.moa ,
I hope you're doing well. I have contacted the developers on this. I can't duplicate it, I get a feeling that something went wrong with the installation. Have you tried re-installing Fusion 360.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
jorge_garcia
Hi @spike.moa ,
I hope you're doing well. I got some feedback from the developers. First, a possible workaround will require using one or both of the these environment variables.
QT_QUICK_BACKEND=software
QT_OPENGL=software
They also asked a few questions, if you could reply the answers to them that will really help.
What about other QtQuick software? like Dropbox.(If you have dropbox does it work without issue?)
What about other dialog? like Team switcher or Insert McMaster.
Does the user have multiple monitor or multiple GPU? What will happen if unplug them?
Does the user have USB display link / dock station?
Thanks in advanced for your attention.
Best Regards,
Jorge Garcia
spike.moa
In preference>graphic driver, I was using "Auto-Select".
When the issue happened, I tried manually select each option.
I think the auto-select uses DX11 because when I choose DX11 the issue remains.
I selected DX9 then something wrong with the tool bar.
Finally I choose OpenGL Core Profile, and it works.
PS: The VGA driver was up to date.
I don't know if the above helps.
Reply to the dev team:
1. DropBox works ok.
2. "Insert McMaster" works ok
3. I use I7-7700 internal vga. Single monitor with HDMI connection. No other display devices. (This is a really simple computer.)
**pcb designer and schematic editor are both good.
jorge_garcia
Hi @spike.moa ,
Thanks for the response, I've let our developers know of your response. Let's see what they come back with. Using the OpenGL core it sounds like everything is working for you. Is that correct?
Best Regards,
Jorge Garcia
