I want to create a simple clearance hole for a metric screw (i.e. m6x1). It seems i have to first select the "tapped hole" option to choose the screw standard and size of m6x1. But the size of the screw diameter, the screw head, and the countersink are all incorrect from the ANSI standard. For instance the hole diameter is 5.035mm and the screw head is 5.539mm.
What am I doing wrong?
