Announcements
Couldnt reinstall fusion
utzl_der_erste
Observer
utzl_der_erste
Observer
Observer
After i closed fusion because it took to long for me to "finish a mesh" i tried to restart it but an error occured.when i then tried to delete it the uninstaller just closed itself and when i start the installer it stops at 99% and says that it doesnt what the problem is
jhackney1972
I would try this.  Find the Webdeply folder and remove it.  This is a hidden folder in Windows so if you do not see it, search the web to find out how to show hidden folders.   Please note, your Windows user name will be substituted for mine indicated by the red arrow.  After this, make sure you right click on the Fusion installer and select Run as Administrator from the right click menu.
John Hackney, Retired
utzl_der_erste
Observer
Observer
i tried it but it still didnt work and send the same error.i didnt get what you meant with the username getting substituted though.
richardWXD2N
Community Visitor
Community Visitor
I have exactly the same issue. I'm not able to re-install Fusion. Log file is the same.
richardWXD2N
Community Visitor
Community Visitor
I have the exact same issue, log file is the same. I cannot re-install Fusion.
