Announcements
Copying and moving sketch lines removing a dot
infoYYJRS
infoYYJRS
Hey guys i can't  remove a point  and i can't copy and move  my sketch lines, what am  i doing wrong?
dsouzasujay
Looks like a duplicate post, Link to another post
https://forums.autodesk.com/t5/fusion-360-support/how-to-get-rid-of-a-point/m-p/10036155
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
jeff_strater
that point is the center point of the circle.  The lines do not converge at the center of the circle
Jeff Strater
Engineering Director
jhackney1972
The entity you are pointing to is actually two points on top of each other.  One is a Point and the other is the center of a construction circle.  Once you remove the sketch constraints on them, you can separate them and remove the Point but you cannot remove the circle center point unless you remove the construction circle.
John Hackney, Retired
