As you can see, I copied the bottom plate component, but the wheel assembly, which is a copy of the other wheel, disintegrates. However, it returns to normal when you drag it around.
At the end of the video, I tried repeating the process but only copying the problematic wheel assembly. It doesn't break.
The copied "wheel assembly" subcomponent is fixed to the bottom plate with a revolute joint.
Is this a bug?
Here's the design: https://a360.co/3QFOx6r
