Copy & Move pivot point
dwsnyder
dwsnyder
Draw simple rectangle 1 1/2" x 3 1/2"
drag to select all elements of the rectangle (8 elements should be selected)
type M for move command
Notice the pivot point that is highlighted (maybe top left, maybe top center, maybe bottom right etc...)
now deselect and reselect elements again... pivot point is highlighted at a different point on rectangle, why and how to cause Fusion to always have the same pivot point?
jeff_strater
There is no way to create a set pivot point for a group of selected entities.  As you've discovered, the default pivot is relative to the entities selected.  You can change the pivot for an individual instance of the Move command, but that is effective only for that instance of Move.
Jeff Strater
Engineering Director
