Announcements
Converting SLT to editable Fusion File
bs
bs
I have a SLT file that I wish to import to fusion and edit.
I have followed (or tried to) many tutorials and failed miserably, so please help!
The attached STL file is that of a netball with the actual ball missing, its like the engraved part of the ball only.
I wish to add a sphere to the centre and enlarge the sphere to it intersects the stl file and so creates the ball with the stl image engraved / sunken just below the surface of the ball / sphere that I add.
I can insert the stl via mesh. but dont appear to be able to convert it and when I draw the sphere I can set its size correctly, but can not achieve the engraved line effect.
The stl is attached.
Can you help please? - Spent hours so far.
Replies (7)
Joshua.Aigen
Hi @bs, I just had a post similar to this. This maybe one of those occasions that working with meshes is better than converting. I created a screencast on what I did check it out. Sorry about the background noise I forgot to remove the audio before uploading. Edit: Making the sphere slightly smaller will resolve the small artifacts.
Joshua Aigen
Workshop Supervisor
jhackney1972
STL file converted and moved it to the Origin for you to use.  Model attached.
John Hackney, Retired
bs
Thank you for the video.
I am almost completely certain i am following your video, but I don't the same result??
I am importing the original mesh and i move it to the origin.
I create a sphere of 61mm diameter which creates a new body. (61 is 1 mm larger than the mesh)
I create tesselate
I then combine.
I select the two meshes
I select cut option
I get an error - yellow triangle against the original mesh that says it does not have a positive volume and everyting disappears.
Can you provide further assistance?
bs
Hello
Thank you for your help, I really appreciate it.
However, I am no further on :(.
I have opened your converted file and then I draw a sphere from the origin to just a bit bigger size than the "mesh", but no matter what option I choose, cut, intersect etc, I get nothing or a solid ball??
Please could you advise further?
jhackney1972
Take a look at the Screencast.  You said you were making the Sphere a little larger than your converted mesh body, this is probably the problem.  If you want less cut in the sphere, this can be done also, I just did it with sightly less than the existing size.  Model is attached.
bs
Hi
Thanks for the new video!!
I will try this asap and let you know.
Thankyou
bs
Hello.
Thank you for the second video.
It works just fine!!
Thank you again.
