When I try to draw a circle as, or convert one to, a construction line the circle will disappear and the UI render becomes extremely jerky. If I click elsewhere I'm unable to select it again and must use Undo to remove it. The UI returns to normal afterward. So far this is the old sketch shape I use that has exhibited the problem.
