Announcements
Converting a solid object to a sheet metal object?
Bryancierniak
Bryancierniak
I have a part in fusion that i made, its a bracket for my 3d printer, i need some way to convert it to sheet metal so i can manufacture it... Is it possible? if so, how? Thanks!
I linked the full part below.
jeff_strater
this is the tool you would use, but in this case, this is not a valid sheet metal design
This design is simple enough that I would probably re-create it using sheet metal commands.  You could also start with just Body1, and add the tabs as Flanges:
Jeff Strater
Engineering Director
jhackney1972
As @jeff_strater mentioned this component is a very simple one and could probably be modeled in sheet metal quicker than converting it.  Since you wanted it converted, I have gone through the process as I see it in a Screencast.  Model is attached.
John Hackney, Retired
