Announcements
Convert Object (OBJ) To Solid (Native Level Fusion Part)
ThePieMonster
ThePieMonster
I have the attached OBJ file that I am trying to convert to a native level Fusion 360 file.
(No mesh or triangles present).
I would be interested in seeing someone record a video of them converting this file so the community can learn from.
g-andresen
It goes like this:
For more complex objects it is recommended to reduce the number of triangles.
günther
davebYYPCU
I do believe the request was for the prismatic version, (no surface triangles middle option) which delivered errors my end.
Might help....
TheCADWhisperer
@ThePieMonster
See Message 18 in >>this thread<<.
Basic Fusion modeling techniques.
TrippyLighting
This particular object or collection of objects should be done with the prismatic conversion, which is not available to people with a free subscription.
It also works mostly with geometry so simple, that is it better to design the parts from scratch with the native tools in Fusion 360.
As @davebYYPCU has mentioned, attempting to do that returns errors.
As such I'd follow @TheCADWhisperer's advise to redesign this from scratch.
ThePieMonster
@g-andresen  @TrippyLighting
It goes like this:
This is what I have tried in the past and was not happy with the results. Also I have the free version and Prismatic Conversion is not available. 😥
@TheCADWhisperer
Thanks for the post.
In the case of this question, I was only interested in a "quick" way to convert the model from mesh to body as a test.
(I dislike when uploaded models are only STL/OBJ and not something more useful like a STEP.)
It would be a 'cool' feature to have Fusion attempt some auto-redesign on meshes as a separate application (or is this what prismatic mesh conversion does)? I have not seen it used before and would be interested in seeing the process like @g-andresen did with his video above using the complex mesh model I provided.
