Message 1 of 11
App Version: 2.0.13377
Category: Serious Bug
Reproducible: Always
Platform: macOS/ARM 64/Rosetta 2
OS Version: 12.4
Severity: Moderate
Summary:
The "Convert Mesh" operation sometimes generates incorrect geometry.
Steps to Reproduce:
1. Import the attached stl file.
2. Observe the geometry at the southern end of California.
3. Use the Mesh → Modify → Convert Mesh operation, using the Parametric operation.
Expected results:
The generated Model should have identical geometry to the input mesh.
Actual results:
The resulting model has triangle fans inserted in place of correct geometry at several locations, particularly at the southern end of California
