Have an ongoing problem where I cannot move a line, but no constraint is showing. It happens occasionally and I have to delete the line and re-add it to allow me to move.
The attached file exhibits the problem. Edit the last sketch. On the left is a vertical line that I wish to drag the top to set the line to an angle but it won't let me. Have noticed that when I drag the top point in the vertical direction a "Ghost" of a vertical constraint is drawn, but when I release the end, and select the line the constraint is not show, so cannot delete it.
Don't know if it is a display issue or not. For now I will just delete the line and re-add it, but it would be good to know why this is happening
