Announcements
Construction plane along path - How to maintain the angle of the plane?
arcookeE4Z3W
arcookeE4Z3W
When I use the Plane Along Path, if the dialog box is open, it shows the plane at an angle.  This is the angle that I need to sketch on.  The "up" direction of my sketch surface needs to be offset from the global coordinate plane.
However, when I press OK, the angle of the plane disappears and the plane is reset to the global coordinate plane.
How can I preserve the skewed plane to sketch on?
Thank you 🙂
g-andresen
please share the file
File > Export > save as f3d on local device > attach to next post
günther
arcookeE4Z3W
Well that's unfortunate... I went to export my file and evidently it got corrupted during the save, crashed Fusion 360, and my work was lost (no recovery files available)
I guess I will have to recreate this and get back to you later
g-andresen
If your file is stored in the Data panel, it will still exist in that location after a failed export.
günther
