Constrain triangle vertex to midline of body
Hi all,
I have a triangle sketch, and would like one of it's vertices constrained to the midline of a body such that, when I resize the body, the triangle (and its extrustion) will adapt.  The pink line in the image below represents the midline of the face of the solid body, and was drawn outside fusion 360 to illustrate the constraint i'd like to enforce.  Any thoughts on how to do this?
Alex
davebYYPCU
You have a sketch on the side face of the body,
1. add a Point to the midpoint of the black horizontal line.
2. add a vertical constraint from the triangle vertex, and that new midpoint.
Like this
Might help......
thanks!  didn't realize the vert/horiz constraint would work on points...
