I have two parts that fit together. I normally start with the diameter sketch and then project it into a sketch for the bottom and top components. In the base sketch the diameter of the circle is constrained to the origin and set with a parameter. The base sketch is fully constrained and locked. I project the base circle into the bottom sketch. I then draw the circle in that sketch by snapping to the projected circle. I'll be darned if I can get that circle in the bottom sketch to change diameter when I change the parameter that drives the diameter of the circle in the base sketch.
1. Am I just confused on how the bottom circle should be constrained by the diameter of the projected circle from the base sketch? I have been working around it by just setting the diameter of the circle in the bottom sketch to the same parameter I used in the base sketch.
2. Do I lock the diameter in the bottom sketch? This seems to lock it to the current diameter and then when the parameter is changed in the base sketch the circle in the bottom sketch doesn't change.
3. I found another workaround where I draw a sketch line in the base sketch for the diameter of the circle. The circle is then constrained by this line. If I project this diameter line from the base sketch into the bottom sketch I can draw the circle using that and it changes with the parameter change in the base sketch.
It seems like I'm close, but feel that I should be able to just draw the circle in the base sketch and use it to constrain the circle in the bottom sketch.
Looking forward to your always insightful replies.
