After an update few weeks ago, my cursor constantly blinks the busy cursor when Fusion 360 is open. From my work history I can see that this was update was released somewhere between november 26th and december 12th, I'd guess it was much closer to latter.
The bug appears even when I have uninstalled Fusion360 with your cleaner and installed it again without even logging in.
I can trace the problem to "AutoCAD component", or AdCefWebBrowser.exe. It takes 1-2% CPU load while idle and if I kill that process, the cursor returns normal. But obviously this isn't solution, because then data panel goes blank. My CPU is 6700k, so that ~2% is pretty heavy load for an idle process.
The cursor keeps blinking even when Fusion360 isn't the active window. It doesn't affect performance, so I can still do most important tasks just fine, but that blinking does cause a headache if I try to work with it any longer period of time.
