Announcements
Consist Upload Fails
kiwison17
kiwison17
So I've been trying to upload a file and I've been persistently getting the same result and I'm stumped. I've tried searching the forums and I've found other problems similar to mine but doesn't help me. I am newbie to F360 so I may just be missing something. This is a friends File he has made in Blender and then I've used this link https://3d-convert.com/en/convert/obj-to-stp.html to convert it to a STP file from a OBJ so I can import to F360. When I upload the file it gets to around 50% and then just idles there forever. I've also tried opening the file in F360 using the CTRL-O open command and my pc simply crashes consistently. failed.PNG
dsouzasujay
Hi @kiwison17 ,
Can you please attach the .obj file and .stp file to the next reply?
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
kiwison17
the step file is too large to post here.
dsouzasujay
@kiwison17 ,
Try to upload the same file from A360
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
kiwison17
this worked but now when i try to open the file in F360 this appears in the top left my my screen and it stops there every time.
