I am stuck getting this error, and the file can now not be updated in a referencing assembly. How do I fix this?
The repair never succeeds.
Can you share your applogs? We are investigating this now and your logs would be helpful.
Cheers,
Karina
We have found a workaround while we are working on a fix.
To save the design, make a change to a theme table. It could be a value in the theme table, or add a row, etc. Then try saving again.
Saving without making a change to a theme table may give the same issue (configurations fail to save, repair kicks in).
Let me know if that doesn't work, or if you run into any additional issues. I'll update here when we have this fixed as well.
Karina
This is fixed. I expect there might be a final repair prompt that works if last save resulted in repair prompt. Theme table edit workaround isn’t needed.
I have the same issue.
please, let me know if there's a way to fix it.
