Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
This seems to be a trend in many applications to make the scroll bars smaller. This is not too much of a problem with vertical scroll bars because I use the mouse wheel to scroll. However, for horizontal scroll bars I have to actually click on it and when it is too small it can be hard for some of us to position the cursor in the correct place.
In the image below you can see how large the standard scrollbars, provided by the operating system, are.
The Fusion 360 parameters dialog uses standard size scroll bars.
The data panel uses small scroll bars.
The configuration table uses too small scroll bars.
Please make the configuration table scroll bars at least as large as the data panel ones.
Solved by gautham_kattethota. Go to Solution.
