I found an issue with configurations where it slows down fusion the more I use a certain configuration.
I have a parametric design for a kitchen cabinet and I created some configurations that alter the shape of the cabinet.
The first two shapes seem to work fine as do the configurations for the amount of drawers or for the types of doors. But when I switch back an forth between the third shape (the one with the angled top) the problems start to arise.
The first few time that I use it everything works fine but the more I change the shape back an forth the more fusion starts to slow down. It seems to get slower and slower every time I select/deselect this configuration.
Also other simple things (like opening a sketch) become a lot slower after alternating the shape configuration a couple of time.
If I save the file as a new version after it has started to be slow and then open it again, the slowness remains.
If I open the previous version (the one before where I haven't yet flipped the configurations back an forth, causing it to slow down) and save this as my latest, close it and reopen it. Then everything works again at normal speed until I start to flip between configurations again.
I've done my best to highlight the issue in the video as best as possible. I've switched between the angled shape an normal shape only once because as I mentioned every time it takes progressively longer and I didn't want to end up with a 10min video. 🙂
