First, the name field of the theme table should be editable. Renaming the theme table using the column name in the configuration table is less obvious. However, this is like most naming in Fusion 360, which is that naming is an afterthought and the user must explicitly perform an extra step to go back and give things meaningful names.
My suggest is to always make naming part of creation in the simplest way possible. Designs are much more useful when everything has a meaningful name instead of sketch1, body3, component2.
It really does not make sense to have themes (composite configuration columns) without user given names. I would suggest that when the user moves configuration columns to new theme table
- if only one column is selected then the theme table is named the same as the existing column name
- if multiple columns are selected, then the cursor should be positioned in the name field of the theme table for immediate entry of a useful name.
