I created a hole in the bottom sketch of my housing, but have some questions:
1) I extruded the first hole in my sketch and copied it, but neither hole shows any depth in the 3D view (photo shown) unless I set the housing opacity to less than 100%.
2) If I select edit mode for the bottom sketch, only the first hole circle appears, not the copy (photo shown).
3) I really want to snap new hole copies to the intersection of the inner construction circle and the straight construction lines (90 degrees apart) (see 3D photo), but I see no snap at these coincident intersections and instead have to zoom in by a factor of 10-100X to be sure that the hole center aligns properly.
4) If I rotate the 3D view to the bottom face (orthogonal), I can click on the center of the original extruded hole to verify its Cartesian coordinate, but the copied hole displays no center mark (see photo).
Thank you very much for your help!
