I'm making an object that a few parts are duplicated. I follow a tutorial to make a furniture and learn how to create parameters.
Flat-pack furniture
In this video to duplicate the legs, he shows to copy the component and then to paste new, so we can manage the other leg alone. But a few time when I made this function, I rotate my leg or other support and when I modify something on the sketch of the new component, somehow the component returns to its original position. So even if I rotated at 90°, it come back. Same thing for a component that I copy and paste new and that I move vertically, when I change something like for example an hole in the sketch of the new component activated, well it returns back to the top.
It happens also to someone else and he did not understand either why the component react like this. It's become annonying!
You can see my object on the printscreen below. I copy and paste new from the cricular component above and each time I modify something in my middle and bottom one, they returns with the circle on the top. Same thing for the support on the center that I must rotate at 90°.
Hope my English is not to awful.
Thanks a lot for your help.
